Ubernoober »
https://forums.nicoclub.com/ubernoober-u14357.html
Mon Oct 18, 2004 3:06 pm
You mentioned 300 HP as a number. A completely reasonable goal.
I am simply going to kinda summarize what the smarter guys above me said and then throw in my own $0.02.
Cheapest thing you could do: replace timing chain with Nissan kit, replace factory cams, start her up. Not the smartest thing to do with all the trash you said got into the pan. A better choice would be a full rebuild. You will have a fresh engine and no gnarly little flakes of metal will show up later to ruin your engine and your day. How would you like to plug an oil galley, lose pressure, burn your turbo, and spin a bearing from a sliver of aluminum hiding in your engine. Ick.
Take the engine to a reliable machine shop. Ask for a factory rebuild but use forged pistons. Lower compression is your choice but for 300HP the concensus is generally the Arias 8.8CR or Ross 8.5CR. Any good shop will hot-tank or chemically clean the block, magnafux (check for cracks) the block and crank, and measure all tolerances to determine if you need to resize bearings or not. From there they should be able to quote you exact price for all machining and assembly required, if they already haven't. Always have all plugs removed prior to cleaning and replaced. Always use new main and head bolts. If you resize the rod ends always use new rod bolts. New gasket set since the darn thing is already apart (I like Felpro).Thats it for the basics. This will deliver reliable power (this assumes tuning competence. Anything can and will break). Additional stuff is just a safety margin or a comfort thing added as a wallet allows.
Extras: Full rotating assembly balance. Most shops will perform a basic balancing job, but good shops will match piston and rods to one another, then balance the entire rotating assembly. I like this and will pay for it every time.Crank and/or Rod mods. Nitriding, shotpeening, knife-edging, micropolishing, lightening, cryo, you name it. All have their benefits. The stock crank is not a weak unit and will do 300HP without complaint. Doing work on the rods can gain you a margin of safety for detonation, but if you are running correctly should handle 300HP fine. Excess RPM will be bad for stock rods. Knife edging a crank allows it to "slice" through any oil that may be sloshed up on acceleration or in a turn. Less resistance and foaming of the oil. It also makes the crank more efficient at flinging the oil off itself. Marginal benefit for daily driving.Nitriding is chemical surface hardening, the crank will have to be checked for straightness after this. Shotpeening is impact surface hardening. Both are trying to stop surface risers from propogating microcracks which can develop into failure points. Polishing/removing stress risers off the entire rod/crank and then surface hardening is also a method. Unless you make big power or rev high, I can't see paying for this. Maybe on the rods.Lightening the KA valvetrain. This would include titanium retainers and the like. Why? The KA valvetrain is not a weakpoint in this engine as far as I have experienced and read. Its good stuff up there. Well, except for that gawdawful timing chain. The new Nissan timing chain kit fixes the problems there.Headwork. A "port" is reshaping and resizing the ports. A "polish" is a fine tasting sausage, or alternately a guy from Poland. Also, A "polish" means that the port is cleaned up of factory flash and a small amount of polishing and radiusing of corners, but no dramatic changes to port shape or size. Simply removing factory flash around the valve seats usually offers the biggest gain. Not necessary but if you have a steady hand and some spare time, its not difficult. DO NOT damage the valve seats, unless they are recessed and shot and need replacing anyway.
Hopefully the smarter guys will come back and correct any errors.
