240marcuSX »
https://forums.nicoclub.com/240marcusx-u5199.html
Fri Jan 28, 2005 10:49 am
yeah that definately sounds like your cables.. while the car is just sitting there pull up the ebrake, and look at the pads, and see if they are clamping onto the rotors,
1. if they are not clamping , then it is your cables
2. if you are missing pads, this could be the problem
3. tighten the 10mm nut through the little hole on the driver side of your ebrake, this makes the hand brake more sensitive, maybe yours is just extremely loose??
4. get under the car and follow the cables, see if they are broken or simply non-existent.
do these 4 things then report back to base, and let us know how it went.
