help me please.
gemo
I just bought a 89' fastback and start to get it to run properly because it produce double the amount emmisions. So what i've cleaned and replaced so far is the AIV sensor,PVC valve, oxygen sensor and the MAF sensor but when I cleaned the MAF sensor and started the car the idle jumped up to 1500 and it used to be at 750.so what could it be?
SOHCSE
Car: 1990 240sx SE
It could be possible that someone adjusted the idle screw instead of fixing the idle issue. That could be the reason that when you cleaned/replaced those parts, the idle was high. See if you can get it corrected with the idle position screw.
Axel Grungy wrote:look at the intake manifold from the passenger side,find the bottom and follow it to the firewall, youll see a hole maybe the size of a penny with a screw inside. HTH
That is where it is. Also, check everything going to and from the EGR.
