HELP ME PLEASE!!!!!!
blackbeltclub99
Car: 93 RX7
I need help I am having an RB20DET swap done to my 91 s13 hatch. I am having a problem. I have no spark. I was wondering if there might be something I am missing. Please help me if anyone can. Thanks so much.
Thanks,Hunter
mmatl16
Car: 240sx rb20 swap
your gonna need to be a little more specific....how far into the swap, etc, etc....
blackbeltclub99
Car: 93 RX7
I have everything done all wired up. I had the car out and it just bucked real bad so I pulled it back into the garage. Then after I played the the throttle control sensor it was ok. now I don't get a spark at all. Everything turns over and turns on but no spark.
mmatl16
you could have fried your ignitor
blackbeltclub99
Car: 93 RX7
How would I test that?
Wulfgang
Check your ECU for error codes first. FIRST.
Eikon
Car: 71 240z, 93 Supra TT
Cam Angle Sensor bad? If it wasn't reading correctly, the engine wouldn't send any spark at all.
Check the connection pins on the ECU... Mine just needed to be bent back into place a little bit.. they weren't connecting properly.
Test a new ignitor pack to see if that is the issue.
