theman4444 »
https://forums.nicoclub.com/theman4444-u37538.html
Wed Jul 19, 2006 7:00 am
First of all the 89 body was a manual and the DOHC Block came from an auto, but that doesn't matter. So we put in the DOHC manual engine harness and we THOUGHT that there wasn't a plug but there was. We were just confused because there is a three pin plug on the TPS that's not used by manuals, but it wasn't capped off because the block originally came from a automatic. I don't think this is my problem anymore.
Although we are still having some problems getting the car running... It'll start after pumping the gas but then you have to keep your foot just slightly on the gas to keep here going. I could use some help there if possible. I'm going to make another Topic called, "DOHC swap : won't IDLE" if you guys would like to help there. I'll explain more in there also.
