s14selfbuilt »
https://forums.nicoclub.com/s14selfbuilt-u39659.html
Fri Aug 11, 2006 4:44 pm
car wont start, fuel pump is turning on properly sounds a little loud, is that normal for a walbro fuel pump? also relay on inside of car, is that supposed to click on and off while starting? tested for injector pulse and im getting a pulse from the negtive side (right side of injector plug) and im getting a signal from the + side when the key is in the on position, with injectors out they wont spray any fuel, tryed clamping the return line on the fpr side and lines just built pressurehow are injectors not opening? also my crank angle sensor has a crack in the outter plastic when the cover is removed...could this cause the ecu to not throw fuel, if so how without doing it electronically???? hah im lost, any help would be appreciatted
