So against all that stands against me I've decided to get a JDM 180SX vs buying an R32 Skyline GTR...for these following reasons:
it's 1/2 the priceI can get a block heater for the CA18 (The car HAS to start in -50C temperatures)Parts are easier to findIt can look sexy (s15 front headlightI like Autoxing, the GTR is too heavy and big for that.
Then I've decided to go this route instead of buying a 240SX and dropping a CA/SR into it because:It's JDM Yo (jk)Because for the price of a *good* used 240 here costs the same as importing a 180SX from japan.The only people I would trust with an engine swap of this nature, wants to charge $12K (canadian) and 3 weeks of time...*cough* All the 240SXs here arn't modded, are rusty, and no one has done anything more than springs intake, headers exhaust.
So I've kinda layed out my goals, tell me if you think they're reasonable (as of now I currently have no budget) I also have my 2003 Spec V, fully owned by me, which will be sold sometime in the middle of the 180SX project to fund the 180SX even more
My goals: 350wrhp with a low 12 sec 1/4mile time on normal STREET tires. And something that handles well. (I'll probally want some advice on parts and soforth) Instead of making 20 billion posts on every question here, I just decided to make one HUGE post. Questions will be marked by Italics and will be restated at the end of the post
My goal is to have the car by the end of april 2005, when I can start on everything, but everything requires a budget, and I want to get on that early
So this is kinda my project overview in the order I kinda wanna do everything:
Suspension:Zeal B6 Coilovers (if you know something better, tell me, but I like these because the spring rates will be nice for the streets of my city)Front/Rear Cusco Strut Tower BarsFront/Rear Whiteline Anti-Sway BarsNismo Power Brace17" Rims of some kind, Khumo MX tiresQuliafe Limited Slip Diff
Engine: (I'll probally need some questions answered here)CA18DET engine rebuildDisco Potato Turbo (hopefully this will be good enough)Camshafts (I'll need to know how these work in order to help turbos obtain the most power)Metal Head GasketT28 Wastegate of somekindRecirculating BOV (if it's needed)HKS FMIC kit3" ExhaustGreddy DownpipeZ32 MAF550-600cc injectors (Is this enough fuel?)New Fuel PumpStand Alone ECU. (Which one do you guys recommend for dyno tuning?)Lightened flywheelValvespringsManual Boost controller (before I get the standalone)Aftermaket oil cooler(Am I missing anything else?)
Misc PerformanceShort Shift KitLarger BreaksZ32 Master Cylinder
Exterior
S15 Front headlight conversionS13-->S15 conversion fenders (Does anyone know where I can get metal ones or urethane ones, unlike the ones sold on import fan.comCarbon Fiber Hood180SX K style Tail lightsSome sort of red paint
So what do you guys think? It's quite a bit of coin...but if I just aimed for the performance stuff, I should beable to do it after I sell the spec v.
Well obviously there are some things I'll be doing first, but I'd like to put them in that piroirty, but an alarm, immobilizer system, and a Mp3 player will come first
But My Main Questions:1) How do Cams help with the powerband with a turbo? Like What effects to the duration and lift effects of cams have in respect to turbos?2) What parts should I have shipped over for the CA18DET engine rebuild, since I can have them put the parts in my car, and just have those shipped over3) I'm pretty new to the CA engine, before this I was studying up on the RB (which I'm still a n00b at) and the QR (less of a n00b). 4) What do you guys recommend in terms of a simple to use tunable stand alone, I was leaning towards the Power FC.5) Trouble Parts of the engine6) I'd like to know a reasonable redline I should set the engine at...7) Is the Disco Potato Turbo good enough or should I be moving to GT2530/GT2535s? I was recommended the Disco Potato Turbo over the otherones because aparently it has VERY good spool up time, and can handle alot of boost.8) Where are some good places for Urethane Conversion fenders to S13-->S15? Or are the importfan.com ones good enough?9) What else should I know about the engine?10) Any recommended parts that I should remove/add to my list?
Thanks for your time
Daemos
