randybunctious »
https://forums.nicoclub.com/randybunctious-u3376.html
Sun May 09, 2004 6:06 pm
that guy is a dumb ***. if the valve stem seals are leaking or slipped down on the valve you could burn oil so slowly that you wouldnt notice smoke. to fix this you would have to take the head off and replace the seals. it usually isnt the stems nissan valve stems last a long time. check around your oil filter and oil sending unit, oil pan, harmonic balancer.oil pump, valve cover for leaking oil, does you clutch slip more now? you could do a compression test and see if your rings are worn buy recording the results , then pouring oil in the cylinders , do another compresson check if the comp went up the rings are worn to the point of burning oil
