HELP me pass emissions! So close!
AZ89two4Tsx
Alright guys, just failed, barely. I am in AZ by the way. We have some of the most strict laws, I think second only to California. So this might help some other people that have emissions/smog coming up.
Car: S13
Redtop SR, S15 turbo, FMIC, hks vented to atmosphere, hi-power exhaust, no egr, no charcoal/evap, brand new catco cat, Power FC. It's also running on low boost, around 8lbs. Not running the greatest either as it needs to be tuned.
I ran the car to 1/4 tank and added two gallons of denatured alcohol. I also retarded the timing -10 degrees via the Power FC before they drove it on the rollers.
HC (1.60) - 1.75 FAIL
CO (15.00) - 3.15 PASS
NOX (2.50) - 2.51 FAIL
Fuel cap - PASS
Pressure test - PASS
Evaporative system - FAIL
Did I retard the timing too much? I was debating on whether to pull 10 degrees or five. I know the alcohol helped.
Also, to pass the evap. system, do they do some kind of test? Or is it just a visual?
Lobo240sx
Car: 1991 Nissan 240sx Coupe SR2.35DET Redtop Build
Get a proper tune. That would be my first step. Not sure if the charcoal canister is visual or not, but I would leave all that garbage in your car and run some random hoses everywhere. Is that cat a high flow or a factory replacement?? I asked because you might need a factory replacement California emissions cat.
You can use a Z31 cat. It is going to be a tight fit though and will rub a little. Depending on your exhaust. It will only be temporary. Sea foam and "Guaranteed to Pass" should be your two best friends now lol.
ciscos13
Car: 89' 240sx hatch, s13 sr
this info will be usefull for my upcoming emissions. let me know what you do to make it pass if eventually you do. luckly this year i didn't had to go to emissions. Good luck.
AZ89two4Tsx
Ended up getting the car registered without having to go through emissions. Kind of annoying that I spent money on a cat and the alcohol, but in all honesty I really don't care. It's legal now.
But a tip for those having to go through emissions, the alcohol really helps, A LOT.
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
How do you register it there without having to go through emissions?
AZ89two4Tsx
Can't tell you that. :D
OM3GA
uhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh
ciscos13
usually you have to pay to "make it pass". or know someone who works in the dmv.
AZ89two4Tsx
If you're in AZ and are really interested, pm me. I can point you in the right direction, but it's really nothing special.
It's not like some crazy unheard loophole in the system.
c29875
Car: 1990 240sx s13
Hey man I'm from Tucson AZ and I would really like to know how you got past emissions.
I got my car registered and don't have to pass emissions until October, but I would like to
know what to do when the time comes.
I have no idea how to p.m. people on this site but my e-mail is [email protected]
ciscos13 wrote:usually you have to pay to "make it pass". or know someone who works in the dmv.
Incorrect. Doesn't work in AZ. All our emissions testing facilities are State-run, and automated, so there's really no way to "game" the system. Fines for bribery and falsification of results are huge.
This is why I contend that AZ's emissions laws are more strict than CA. No "homey hookups" here.
Christian, did you use my tried-and-true method? ;) If so, well-done.
ciscos13
lol, i just got my friend to pass his car without having to move his car out of his house... im telling you, you just got to know people around. The system is never perfect when money is involved and the economy doesn't help. :whistle:
chicos240
Car: 1995 240 SX
AZhitman wrote: Christian, did you use my tried-and-true method? ;) If so, well-done.
AZHITMAN...you are such a tease.
AZ89two4Tsx
Hehe, I tried, but they wouldn't let me....the insurance company that is.
Efrain helped me out a bit. ;)
DrewPeacock
Car: 1993 240sx s13 silvia
AZ89two4Tsx wrote:If you're in AZ and are really interested, pm me. I can point you in the right direction, but it's really nothing special.
hey I'm in Arizona and I have an SR20 s13 coupe and derperatly need her to pass emissions, if you could help me out it would be GREATLY appreciated and I have cash if need by please help me out!
