help me out
speedjunkie
Car: 91 300zx TT
ok i jus got a 300zx tt 91 and the oil pressure gauge is wacked everything runs great it jus sorta scares me i was wondering if anyone else had this problem and if i should worry thanks
TT2+2
Car: 1990 300zx 2+2 TT(almost widebody)
good possibility it's a bad sending unit
NSR240sxe
Car: '97 Kouki S14, '98 Sentra SE
Welcome to NICO!!! Congrats on the Z32 post up some pics
nsrZ32
Car: 90 Nissan 300ZX TT
78 Datsun 280Z
71 Datsun 521 Pickup
98 Nissan Sentra 2.0 SE
02 Nissan Altima 3.5 SE
01 Ford Focus S2
Another newbie. Welcome to our Z forum
Its probably the sending unit as mentioned above.
OldSportsCarNut
Car: 1991 Nissan 300zx 2+2 non turbo
Got my '91 NA 2+2 this past May. My gauge seems to do wierd things also, but then, (when all else fails) I looked in owners manual. The manual shows a pretty wide spread (15lbs-70ish) as being acceptable which made me feel better but still seems like lots of variance. I posted similar question and the NICO gang suggested sending unit. My car does not leak or use any oil between changes (150,000+ miles). OSCN
gpelite
Car: 1990 300zx TT
Yea sending units are problematic, are are something that will need to be either worked on or replaced. If all your oil is staying in without loss its not a major thing thus far for the most part. If you have access to install an aftermarket unit as temporary (if you have it layin around or something) you could easily test that. Since most people don't, you could just replace the thing.
My unit changes a lot too, but my car runs smooth and doesn't consume massive amounts of oil. I want to install a more precise gauge to monitor it more accurately however or a better than stock sending unit, I am really picky with readout inaccuracies and taking chances. I want to know what is happening every second to the car and Im the dude with the tech stuff glowing from the inside as I adjust things, thats just me
speedjunkie
Car: 91 300zx TT
right on budd thanks alot and thats how i should hehehe
