Exar-Kun »
https://forums.nicoclub.com/exar-kun-u1725.html
Fri Feb 21, 2003 8:10 am
heres some pros and cons of swapping springs and shocks at the same time:-PRO: labor is the same on the front, since its a strut. you still ahve to take it all apart anyways labor is pretty much the same on the rear, but slightly different because its a shock.-PRO: you'll be done, and have a nice new matched suspension combo for the rest of the cars life.
CON: cost. more parts=more moneyCON: excessive lowering(anything over 1.5") can cause allignment problems, and require a kit to fix it.
those are the big points.-chet
