Nick (ASH-SPEC) »
https://forums.nicoclub.com/nick-ash-spec-u184217.html
Tue May 17, 2011 8:45 am
Another thing you may want to try next time is to fill the block from the hose that comes off the top water pipe. Disconnect the clamp from the radiator and turn that hose upward so you can fill it like a funnel. That way you don't have to wait for the coolant to go through the radiator and into the block, it goes straight to the block. That should help solve some of the air problems. Then once it's filled, reconnect that hose and continue to fill from the radiator cap. Unfortunately you won't be able to do that this time since it's already filled... but now you have a heads up for the next time!
