Ok. First things first.
Compression test.Remove all your sparkplugs. Remove your fuel pump fuse. Screw the test gauge in, and crank the engine. Stop cranking when the needle jumps 4 times. Don't just keep cranking.
Leak down test.If you've got low compression readings, you can narrow down the problem by putting a bit of oil into each cylinder and re-checking the compression. If the numbers get higher after the oil, then your piston rings may be the problem. Putting oil in your cylinders doesn't fix anything. It's just a method of finding a problem.
Air fuel ratio.With out access to a wide band o2 sensor, your SAFC is a waste of time. Stop fooling around with it. Better yet, take it out. I'll bet your car doesn't run rich afterwards. And no, an autometer a/f gauge won't help you, nor will any other narrow band a/f gauge.
Valve cover gasket.Heavy Throttle
http://www.heavythrottle.com//, Phase 2 Motortrend
http://www.store.yahoo.com/pha....html. There are more, just search.
Timing.Set your timing to 15 BTDC. You can use a timing light, I have, and so have many others.
Broken bolt.Get it out. Fix the problem. Don't drive on 3 cylinders.
