93superHICAS »
https://forums.nicoclub.com/93superhicas-u41928.html
Mon Apr 06, 2009 10:37 am
ok. i did the coupe doors and im putting the interior back in.and going to connect the door window main harnes into the verts main harness and there different plugs.
the passanger side plugs right in without problem.
as you can see in this pic, the door window harness plugs.the left blue plug is from the coupe door window harnessand the right blue plug is from the vert's main harness.?????
any advice guys?just skip the plugs and connect the two????
as for the big flat white plug connector, it clips in fine, (door locks work)
