ILikeMy240sx »
https://forums.nicoclub.com/ilikemy240sx-u16757.html
Mon Oct 29, 2007 5:09 pm
Its not bad... its just useless. Narrowband O2 sensor is good at running very close to equivalence ratio of 1. Meaning the stoich ratio of gasoline which is 14.6. It can't monitor A/F ratio like wideband O2 sensors do which has linear voltage output as a function of A/F ratio. Narrowband O2 sensor just outputs one voltage for something leaner than stoich and another voltage for something richer than stoich so with narrowband you can't tell whether you are running the correct A/F ratio you need.
That's why you will see narrowband A/F gauges just jump back and forth between lean and rich during part load operation and just rich during heavy load (WOT).
With wideband O2 sensors that can actually tell you what your A/F ratio is will not jump back and forth between lean and rich but rather tell you the exact A/F raio.
Cliff notes: Narrowband O2 sensor gauge is as good as a disco light on your A-pillar
