Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Sat Dec 08, 2012 7:54 am
Oh, you can remove a lot of stuff >_> As far as relays go, there's really nothing associated with the auto trans that can be deleted. I would just suggest pulling out the wires you know go to the ATCU and its associated switches, sensors, and solenoids. Go through the AT section and EL section of the service manual and make notes on what you have on your harness versus what's in the wiring diagrams. If you can match up the plug to the harness layout diagrams, you can find out what part of the service manual should have a diagram for you to look at. In sections like the AT section, if you go forward to the Trouble Diagnosis page, it will have a sub-table of contents and the wiring diagram will be listed there. Sections like that typically don't list the diagrams in the main table for some reason.
When I started working on my custom main harness, I probably spent a few hours going through the service manual, section by section, to map out what could be removed. Since I did that, I have a fairly comprehensive list of every wire that passes through the Super Multi Junction connector under the driver's dash. I ended up pulling out around 26 circuits, and associated relays, but since I swapped to a Silvia front, a lot of those were related to the pop up motors.
