Help me identify which door handle I have
sigsterrr
Car: 1989 coupe p.o.s.
I bought a 1995 model 240sx shell with a busted passenger exterior door handle. Seemed easy enough to get the right on to replace it. Bought one off a 1997 model and it was wrong. Bought one off a 1995 model and it was wrong. Noone in my area seems to have the type I have and really need it so I can finish the exterior of my car. Here is a picture of the three handles I have. The correct one is on the left. Notice the longer column for the lock to slide in and be held in by a retaining clip. The other two use a bolt in lock that is different. And I even checked if I could just epoxy the lock in , but it the lock mechanism has to go in after the handle is installed. Someone out there has had to have the same problem as me and can steer me down the right path...
sigsterrr
really? nobody knows the answer? :-(
