s13EastTN »
https://forums.nicoclub.com/s13easttn-u15057.html
Sat Jul 03, 2004 6:11 pm
Mine did almost exactly the same thing. Except if yours definately makes the sound in the 2k-3k range, then it's different because mine was also throttle dependant in that area as well. Ok, first impressions where that it was a bad lifter (hoping for the best really) but then it came down to spun bearing, or the chain slacking and hitting something. The shop that is currently fixing my car beleives that there is a large amount of slack in the chain, since my tensioners are gone, and it is causing the chain to do strange things under certain loads. Mine starts at about 2k, and doesn't get louder really as the rpms build, just quicker (a lot quicker than any valve since they open a close a lot faster than this sound happens). Open your hood, have your friend start your car and see if it makes the knock when it first turns on. That would be a sign of a bad tensioner. If the sounds are the same, I would assume that our problems are related and it is your tensioners that are the problem. Hope I helped.
