nissanfreak12 »
https://forums.nicoclub.com/nissanfreak12-u177688.html
Mon Nov 05, 2012 7:59 am
Just get the bushing. You can get the whole tension rod, but unless you had some sort of run in with a curb, they should be ok.
You can either take them to a shop and have them push the old bushing out, might cost a few bucks, or cut out the old bushing. Once you get the old bushings out, there will be a metal race that also needs to come out, that part could get tricky. If you can get a punch and make it collapse on itself, it will come out easy.
Putting the poly bushing in, well that is extremely easy, its a 3 piece design. Pretty easy stuff.
