Help me identify this leak *pics*
Optimus Prime
Ok so i recently noticed a tiny coolant leak on my SR20. It seems to be coming right about my water pump, but i'm not sure if it is , in fact, the water pump that has failed. I figured if the water pump was bad, it would leak from the bottom and not the top.
Either way, here's a pic. Wondering if any of you know where this leak is coming from.
2forty
i could still be the water pump. it may not be sealed at the top? i know im leaking from the bottom of mine lol. not enough gasket maker!
BaliLover
I think there is a little hole in the top of the water pump and when the pump starts to go bad, coolant will seep out of it.
S13240
I say it's the water pump, change it out asap!
boost_creep
Car: 92 sr powered coupe,06 Spec V
ding ding ding....to what balilover said.
2forty
hmmm, sorry to jack, but what if im leaking from the bottom? i have an s14 waterpump on my s13. i was thinkin not enough gasket?
karmakaze
Car: 98 240sx SE
its probably your weeper valve.
574-240sx
Car: Nissans, Toyotas, Subaru
karmakaze wrote:its probably your weeper valve.
change it out, it means its bad.
2forty
hmm its brand new...
