HELP ME ID THESE PLUGS!
AznXstazy
hey guys, I'm trying to attempt a wire tuck, but when i started to ID the plugs that i needed to extend i started noticing plugs that I didn't label before pulling it into the cabin =/
Trying to figure it out, but the service manuals not helping to much. Trying to see if anyone on here knows what they are off the top of their heads.
DRIVER SIDE FRONT FUSE BOX
http://i24.photobucket.com/alb...2.jpg
found this close to my fuse box when i got my car with a sr20 swap in it. it was zip tied together already. looks like a MAF connector?
IGNITOR CHIP
http://i24.photobucket.com/alb...r.jpg
i know that's the ignitor chip, but what are the 2 sensors that are next to it? looks like a boost solenoid? and the other looks like a EVAP sensor?
PASSENGER SIDE FUSE BOX AREA
http://i24.photobucket.com/alb...x.jpg
I know 1 and 2 goes to the engine harness, but not sure what 3 and 4 goes to.
PASSENGER SIDE AREAhttp://i24.photobucket.com/alb...t.jpg
this is where most of the plugs that I'm not sure of. i THINK 2 and 3 are for the windshield wiper fluid motor, but that was removed by the previous owner and those plugs were just dangling there. 5 is a relay to something.. and the rest of them not really sure.
I will be checking the FSM again and try to figure out most of them, but the previous owner did a real hack job =/
any help will be greatly appreciated thanks guys.
AznXstazy
bump bump bump
hboninc19
For the ignitor. 1 is boost solenoid, 2 is air injection
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
This is why I constructed my own wiring harness... I wrapped the s*** out of unused plugs with electrical tape... The 2 things next to the ignitor, you don't need them...
Check this out... It'll help you identify what's what... and what you don't need.. as long as helping you better understand your harness...
http://www.frsport.com/sr20det....html
AznXstazy
thanks, ya i saw those 2 plugs i don't need, but i'm trying to do a wire tuck right now thats why i'm wondering. the motor was already pulled when i got the car so trying to see what plugs go where really. already found most of the one's from headlight, horn, wipers, brake booster. pretty much only ones i really need to extend from the engine bay harness. other ones gonna keep in the cabin and put the fuse boxes in the glovebox or something.
