Help me get rid of Gargling.
JT_MONEY_2004
Car: 1990 Q45, Pearl
After coolant system refill ON '90q, i've got that water-behind-the-dash sound. Can't search archives now, so, someone please post again how to get rid of it. I've topped off several times since refill but sound keeps coming back.
chinaonnitrous
Car: 2002 Maxima to 2004 Evoloution to 1992 Integra
From my experience, TUrn heater on...let system cycle........shut off...
With big towel, open radiator cap....the higher one on your q45... fill....
repeat.
qship96
Car: 1996 Infiniti Q45
just keep recovery tank at proper level and system will burp itself and use coolant from recovery tank as needed to replace air in system over time as car cycles thru warmup-cooldown cycles from normal use-keep an eye on resivour over next few days and top off as needed
Rex
Car: None
Also helps to park with the "nose" as much uphill as possible when the motor's warm/hot. This will help with the burping process.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
I would leave the heat on full blast at all times, and the adjust using the fan.....
otherwise... when the car is cold take off the radiator cap and then adjust as necessary.....
JT_MONEY_2004
A'ight guys, will try one or all those. Thanks.
