93Niss240 wrote:ya i was about to come back and say that.....heh...but u do need some sort of leakproof (air) pipe goin from the turbo compressor outlet to the throttle body....and the vaccuum lines need to be hooked up
180fan wrote:to check for functioning injectors, put a screw driver to the back of the injectors while the car's running and listen in to the back of the screw driver. You'll hear a muffled ticking. Then to test if the injector's actually working without a consult machine, pull the injector plug. If the motor stumbles, the injector is fine.
I have fuel pump powered, and have fuel circulate(left the return line unpluged, fuel squirted out).I also did it manually but the injectors didn't squirt. If it is bad injectors, shouldn't at least one fire? It shouldn't be possible to have all of them to be not working.I'm gonna check if the wires are okay. May be I have bad ECU?toledo240 wrote:Try it manually, if it fires that way then there is something with your wiring.IS your fuel pump turning on at all you should be able to hear it if its a walbro. Have you tried pulling the fuel pump fuse out and put it back in?Do you have fuel by the way?
