Help Me fix my Q!!
CroQ45
Car: 1993 Q45
Hi. I own a 1993 Q45. Body 150.000 Miles, Motor Has 75.000 Miles.My Brother inlaw Just Gave me this Car, I always loved her! My Problem is, When I start her she shakes, and when I step on the gas, she moves slow until I nail the pedal down, then she goes. But I still think she should have much more power then she has! I took her to a shop, ( I will never take anything to this guy ever again), But he changed the intake gaskets and valve cover gaskets, he says he changed the coils and vac hoses. After that I added new plugs and wires, BUT still she's the same. Today I cleaned her MAF sensor. She still shakes (Like Idles Rough) And she has no power! Can someone please help me??
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Maybe somehow you have a 2nd gear start TCU... Try moving the shifter into 1st and see if that helps the power...
The shaking is likely due to some bad injectors..... Look on Q45.org for more infomraiton
qship96
Car: 1996 Infiniti Q45
must be that the new{plug} wires you added !
CroQ45
Car: 1993 Q45
I went for a ride just now, And no the shifter if fine! But when I Nail It I mean Floor It She dont respond Not like she has too!
CroQ45
Car: 1993 Q45
How can i find out if all 8 Cylinders are running?How can i find out if its the injectors?And Are they hard to fix??
rsiwicki
Car: 95 Q45T
there is a Q45 specialty repair shop somewhere in NJ that is suppose to be really good. It would probably save you lots of time trouble shooting the problem to take it too him...then again that means more $$$$. I am sure somebody on here will post the mechanics info for ya shortly or do a search such as NJ mechanic or something like that.
CroQ45
Car: 1993 Q45
I am New to The Q45,Used to be a GM And Ford Man! But so far i love The Q!I wanna add some good parts on her, Spend a few bucks on her.. Can someone Help me by telling what good parts to get her? Like Performance sparkPlugs, Wires, Coils ,Injectors, Air intake And so on.......
nchopp
CroQ45 wrote:I am New to The Q45,Used to be a GM And Ford Man! But so far i love The Q!I wanna add some good parts on her, Spend a few bucks on her.. Can someone Help me by telling what good parts to get her? Like Performance sparkPlugs, Wires, Coils ,Injectors, Air intake And so on.......
Pretty much all the OEM stuff is as good as it gets. For plugs, the OEM Platinum NGK plugs are the best, get 'em here: http://www.q45.org/shop.html . Wires, injectors, and air intake all the same - OEM is quality.
Rex
Car: None
rsiwicki wrote:there is a Q45 specialty repair shop somewhere in NJ that is suppose to be really good. It would probably save you lots of time trouble shooting the problem to take it too him...then again that means more $$$$. I am sure somebody on here will post the mechanics info for ya shortly or do a search such as NJ mechanic or something like that.
Vanmeter Auto Service - Located in Mantua NJ is a reputable shop for folks in the northeast. Keith Vanmeter, a former Infiniti technician now working independently, can be reached at 856-415-2022.
PopPop
Car: 1990-91 infiniti Q45's, S13 Coupe, 3rd GEN. Max
Best to take it to a tech who knows what he's doing. You don't want to play guessing game. Wes was right about shaking most likely coming from injectors. If this problem has been going on for a while the injectors may have damaged oxygen sensors and cat converters.
Rex
Car: None
CroQ45 wrote:How can i find out if all 8 Cylinders are running?How can i find out if its the injectors?And Are they hard to fix??
Here's one of several threads that discuss injectors and the process to ohm them.
zerothread?id=139615
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Have Keith Vanmeter do a power balance test.
Post your results and a brief maintenance history in Infiniti Mechanic Forum.
CroQ45
Car: 1993 Q45
Thank you all for helping me, yes it was the injectors!
CroQ45
Car: 1993 Q45
Thank you~ will do..
maxwell867
Car: 1996 q45
how is your q running know? Does it respond when you step on the gas because i have a similar problem.
CroQ45
Car: 1993 Q45
Going to fix it this week, ill let you know.
goody90q45
Car: 1992 Infiniti Q45 (sold)
Inquiring minds want to know- Which injectors are bad? What are the readings?
