Help me fix my Engine Code!
iamadirtdude
Car: evo 9 & s13
please help point me in the direction of what things i should check .... i degreased the engine bay and now the car will turn over but wont start. the code is number 11 crank angle sensor curcuit. it ran fine until i washed it and before i figured out how to get the code i changed spark plugs, plug wires and check the ingnition module, ignition coil, and cleaned the distributor. ANYTHING i can check will help thanks!
iamadirtdude
Car: evo 9 & s13
bump i need help
iamadirtdude
Car: evo 9 & s13
its a code 11 crank angle sensor curcuit what the heck can i start to look at to determine the problem....the car will turn but wont run ...sometime i get lucky and the engine light goes off and it will run for a little bit....i got it to run 15 minutes last week lol HELP
Goldeneagle
Car: 1992 240sx Coupe
Download a copy of the FSM and follow the diagnostic procedures for the crank angle sensor.
The fix may be as simple as replacing the sensor.
iamadirtdude
Car: evo 9 & s13
what is the fsm and where can i find it?
dkdeleon68
Car: 1991 240
iamadirtdude wrote:what is the fsm and where can i find it?
FSM = Factory Service Manual.get them here http://carfiche.com/manuals020/cars/
iamadirtdude
Car: evo 9 & s13
fixed
