A few things really confuse me...
-The motor runs smooth. Weak, but very smooth. This makes me think it is something general to the fuel or air systems. Not a cylinder specific problem. All cylinders are firing at equal strength. Spark must be good.
-The plugs look fine to me. Maybe just a hair rich, but certainly not fouled. This leads me to think that the motor is getting the correct fuel/air mixture.
-Timing *should* be correct. I know that ignition timing at the least has to be correct. There is no way the crank pulley can be off and no way the timing gun would tell me wrong. Just not possible.
-The ecu is not throwing any codes in self-diag. That makes me think that the electric components are not shorting out with the key on. Now if they read correct when the motor runs is of course a different matter.
-This problem started while I was driving in the rain and at low throttle. Low throttle really doesn't put much strain on the motor. I can't see something breaking from slow acceleration. And even if something broke, I think I would have found it by now. So that means something was affected by the water? that sounds like an electrical problem.. but I have looked at every electrical system already.
So what have I concluded from this?
-Has to be something general to the system. Air/Fuel ratio then?-Doesn't affect air/fuel at all, or much. Must be timing then?-Timing is correct. Must be compression then?-Compression is weird, but should be making power.
So if it has good A/F and still has compression and still runs, what else would effect power? Timing. But timing has been checked so many times now. Ignition timing is not even an issue anymore. So what, does this mean I get to tear down and look at valve timing again? BUT WAIT!!! This all started while I was driving. How the freakin heck could the timing chain jump while I was driving without something exploding under my timing covers? The lower timing chain could never jump unless it destroyed the bottom stoppers somehow.
Sorry for the ranting. I just wanted to share my frustration...
Since this oil leak is so bad I may devote tomorrow to tearing it down... again... fixing the leak, and since it's all apart just check to see how timing compares to this image of the cams at TDC (
http://jimwolftechnology.com/wolfpdf/CA ... KA24DE.PDF)
there's no way I screwed it up 4 time in a row, but there is nothing left. N o t h i n g.
