Help me find a RB25det ECU plug or harness
burnin240sx
ok I have been going crazy tring to find this ecu plug or harness for my series 1.
My problem is I have a harness on the motor but the ecu plug has been cut and I have called jarco and JHOT they don't part out this item. I have not seen a S1 on eaby in like 6 months so i'm in a pickle.
If someone knows some work aound like using a q45 ecu plug or some other source or maybe someone has the PLUG that would be freaking awsome since all i need is this plug for my harness and a working turbo(need new stock center cartridge) and i'm done I hope.
eh?
3rd gen maxima or pre 95 300zx. Their plugs should fit and their ecu pinouts are similar.
Ramius83
Car: 1995 240sx SE
eh? wrote:3rd gen maxima or pre 95 300zx. Their plugs should fit and their ecu pinouts are similar.
Now, when you say 3rd gen Maxima, which model, or does it not matter?
Meaning, for the 3rd gen Maximas, there is a VG and a VE motor. Completely different wiring, ECUs, motor, etc. DOHC vs SOHC, 190 HP vs 160 HP......
eh?
Sorry, should have said VE. I'm not sure about the maxima vg30e.
burnin240sx
i'll have to scout the yards around here and hope for the best
Ramius83
Car: 1995 240sx SE
burnin240sx wrote:i'll have to scout the yards around here and hope for the best
Hey man, if you want, I am going to a junkyard this weekend/Monday in south Atlanta. I know of a VE engine there that may still have the ECU plug. I'll let you know if I can scrounge it up.
burnin240sx
if I could just get a pic of the plug that would be sweet. i'm tring to get a fsm pic from the local nissan via fax but i may just have to take my arse down there and have them print it out.
OKCA18DET
did the place where u got ur motor from specify cut/uncut harness? if so boy i sure would give them a butt chewin if they said it was suppose to come UNCUT...
burnin240sx
I have found that the q45 90-94 will work. The max and the 300zx won't fit they are close but won't fit.
Woot save myself some more $$.. now I just have to find a Q45 at the junkyard. Hope this helps someone out there in the same perdicament as me.
eh?
That's strange, what's the diff between the max/z and the RB plug? The ecu layouts I've seen showed them being exactly the same. :/
Ramius83
Car: 1995 240sx SE
I can stop by my local junkyard tomorrow after I get off of work, around 2 pm. That I know of, they have two Infiniti Q45s, 90-94ish. I'll let you know if I get it or not.....
burnin240sx
the max has plastic pins that line up with the plug in and order of 4 2 2 3
the q45 has them just like my series 1 rb25 and my co workers rb20 these are 4 3 3 3. the 300zx has the same type of connector as well.
I'll post a pic tommorow of what i'm talkign about it will be better understood.
I found this out thanks to all data. It's nice working at a shop with the right tools. you get stuff done ten times faster.
Modified by burnin240sx at 3:19 PM 7/13/2005
Ramius83
Car: 1995 240sx SE
Burnin': Do you still need a plug or did you find one?
burnin240sx
Ramius8,i still need to go get one. but I found out what cars to look for. Do you have one from your trip to the yard? cause It would save me a trip if you did. let me know.
[email protected]
______________________________________________________________________________________
here is a ecu plug for a 89-94 Nissan Maxima______________________________________________________________here is a ecu plug for a rb25det seriers 1
______________________________________________________________here is a ecu plug for a 90-96 Z32 300ZX with VG30DETT
______________________________________________________________here is a ecu plug for a 90-96 300ZX NA with VG30DE
______________________________________________________________They all look the same. also the rb 20det is the same as well
______________________________________________________________Oh yes and the infinity Q45 90-94 ecu[img]burnin240sx.q45.org/ecu_compare/ecu6.jpg[/img[
so in theroy the rb20, rb25, maxima, Q45, 300ZX NA, and 300zx have the same ecu plugs.
This should help the cut harness and broken ecu plug peeps out there.
Modified by burnin240sx at 2:53 AM 7/14/2005
eh?
So the maxima will work? But that's not the ecu i was talking about, should have been the 92-94 DOHC maxima, VE30DE.
