neverlift »
https://forums.nicoclub.com/neverlift-u39984.html
Wed Sep 06, 2006 1:30 am
you call names like a child you must be. If you think bend in the path dont slow flow you are a retard. A 2 1/2 pipe at a 90* bend take like triple the distance to get to the same place. Like I said I dont see your car lined up next to mine to show me ****. My intake sits on just one rad hose that has been heat wrapped which made no difference seeing that the air travels faster than it will matter. Your cold air or short ram does the same. Did you even look at my pic, I have on 45* bend that goes where the battery goes, with a tube that draws in fresh air from 10 inches off the ground. My battery tray is gone and I have an origin front that puts alot of air straight to the intake. My short ram is more like a cold ram. I did not say anything negative about a cold air intake. It is the best set up if you can have it short as possible to keep the needed throttle response. I would go put it on a dyno today, if I didnt have so much other stuff done. My support mods would give my intake a few extra ponies so it would not be fair. That and most dyno charts fail to realize the wear and tear the engine has been through. Even injen. They baseline that one car to test and tune the intake, that doesnt help everyone. Look at k&n remaking thier product after all this time. At first all they had for the e was a filter and maf. Also you want me to stop saying it so you can try to take it. . so until then STFU!! hahaha you /\ How bout this anyone with a stock 90 sohc wanna pay for some dyno time,in jacksonville? I'll even give the person a burnt chip with deviouska tune and a socketed ecu to put it in. So that is a chipped and socketed ecu worth about 80 - 100$. I will do the work and use my parts. You will get to keep the ecu and chip,know how much power you have, know what a homemade intake can do, help me show it doesnt need to cost big money to make small gains. I think I'll post this.
Modified by neverlift at 4:53 AM 9/6/2006
