brisknfade »
https://forums.nicoclub.com/brisknfade-u20471.html
Mon Jan 24, 2005 9:32 pm
When you disconnect the MAF and you rev it, the car usually goes to about 2000 or 2500 RPM then it wont go any higher.
If the computer doesent recieve the info about how much air is going into the engine, then it can't adjust the Air/Fuel mixture properly. So it doesnt let it rev high enough to cause any serious damage.
So that may be your problem. Since you changed the intake and it started doing that there it's probably that. If it is hooked up, maybe the wires or something on it are damaged. The overheating may have contributed to that.
I Disconnected the MAF from my 14 and ran it, did the exact same thing. It keeps on bouncing off of 2200 or something like that.
