chicos240 »
https://forums.nicoclub.com/chicos240-u20799.html
Sun Oct 21, 2007 7:49 pm
UPDATE:I went out on some 0-60 runs by some abandoned buildings.I used stock boost and it worked ok, but still bogging.I used my first setting(which is 15 % over stock boost)...got a little better.I used my second setting( 30% )...working okI used my third (50%) ok, but not fabulous.I used my foruth (75% of stock) so thats maybe .75 x 7 psi+ 7 psi=12.25 psiAnd on 2nd gear I heard a POP sound like a very loud pringles can. Car shuts off.Car starts it gets to 1000 RPM then dies. Over and over.Its pitch black, all I have is a small mag lite. I open the hood and I unplug my TPS ( throttle position sensor )and my MAF ( mass airflow sensor ). Car starts but of course cant rev past 2500 RPM. I turn car off plug in TPS and turn back on and it idles fine. I then Limp the car home at 10 miles an hour for 3 miles. Next morning I looked and it turns out the SMIC ( side mount intercooler ) cold pipe (the one coming out ) has popped its hose, hence the sound I heard. WHich makes perfect sense on why unplugging the MAF made it idle ok.I went through and re did all of my vacuum tubing, and clamped all connections again. Now the car runs beautiful. Turns out I had minor vacuum leaks and BOOST leaks.I am still running rich, but not as badly. Im going to try hotter plugs like the iridiums bkr7eix. Anyone have any thoughts on this. Im assuming that hotter plugs means more burnt fuel and less richness.Thank you all.I write this so others may search and learn.
