Dattebayo »
https://forums.nicoclub.com/dattebayo-u729.html
Wed Aug 19, 2009 1:43 pm
Okay...In order, this is how it goes for VIN:K is first, if you have HICAS
R is for Hatchback and is next, or first if you do not have HICAS
P is for the SR20DET motor option, and will be first if your model is a non-HICAS coupe (HICAS coupe available in Japan only)
S is the model ID, if this appears as the first letter in the VIN, your vehicle is a CA18DET equipped non-HICAS coupe ONLY
13 is the chassis code
The rest are for serial ID only.
You can decode the MODEL code for specific options, but I don't know that information. The MODEL code is located directly underneath the VIN code.
Hope that helps, and Jesus Christ, you could have searched all that up. It's not altogether hard to find that info. Yeesh.
