jr_ss »
https://forums.nicoclub.com/jr-ss-u34795.html
Sun Sep 28, 2008 4:29 pm
Ok, I'm going to sound alittle bit hypocrictal here asking for help, when I know it's all about what I want but, it's so close I need an outsiders help.
I'm trying to decide what turbo to run on my build. I don't want to go top mount, nor do I want an externally gated setup, so I've narrowed it down to 3, the GT2871R .64, .86 and the FP 20g all bottom mount of course (sleeper look)... They are all comparable turbo's with the 2871R .86 and the 20g being closer in terms of spool and capable power levels. My problem lies in my build. I'm building a 9.1:1 motor with a slight port on the head and exhaust mani (mainly smoothing out of the ports and casting marks), which will help with spool times of all 3 turbo's.
Will I out flow the .64? Meaning, would it be better to get the .86 knowing that I'll reduce spool times because to the nature of the beast? The 2871R .64 was my first choice due to the fact that it can make 400rwhp and it is very responsive. But when I think about it, with my build I should be able to spool the .86 at or around the same time someone with a 8.5:1 motor should be able to spool the .64. I'm aiming for 400rwhp, but if I make more so be it. Somewhere, some how, my build took a turn for higher hp than originally intended. I guess I could get the bigger turbo, just to have a cushion incase I want more power (which I'm sure I will) down the road.
The 20g I think will outflow the 2871R in both trims in the higher boost levels, but sacrafice spool time (minimal). I've seen 20g's push close to if not higher than 30psi (not that I'm going to take it there). Where as the 2871R's aren't capable of as high of psi levels, but will spool slightly faster than the 20g.
My build:
S14 w/ VCTToda 264's w/ 10.5mm liftSupertech DVSMild port on headJe 8.5:1Eagle rodsBlock/Head decked to bring comp to 9.1:1Cosworth main/rod bearingsARP head/main/rod boltsCosworth 1.5mm HGNX2000 70mm TB740cc injNismo FPRATI dampnerTurbo 1 of the 3 above
I'm sure I've missed something, but that's the basics and should help determine what turbo I should run. Thanks for everyone that will and has looked.
Glenn
