Luke »
Fri Jan 07, 2005 11:07 am
#1 - That's the "Boost actuator somethingorother" haha. You can remove both things since it isn't necessary to have for the SR to run. I unbolted them from that metal plate and tossed em.
#2 - I'm not sure about this one, my black top has a catch can right there so i'm not sure.
#3 - That larger fitting goes to the T-fitting on valve cover. If you don't have the hose that runs from the VC to that intake tube, cap it. Then put a breather filter where the hose would go on the VC.
#4 - I don't know what your pointing to here, the smallest one can be capped also. Then theres one more that you can use for recirculating a BOV, or cap that also.
#5 - That's the Injen intake filter and MAFS adapter. I have the same exact thing. Just put a cap on that hole to, it went to my AIV on my KA.
