Black hat Centric rotors are meant to be good. I love the Brembo Stillen ones that are drilled and plated. Porterfield makes cryogenically treated rotors which are the kind Q45tech uses (Power Stop?). The OEM sized Brembo rotors from TR are great, but with no coating, they rust like crazy.
I recommend OEM pads and shim kits without reservation for street use. Nothing else will give you as good initial cold bite for when those idiots pull into your lane going 10 mph. Mountains and track will require something more resistant to temperature gains like the Hawks.
I recommend DOT4, my favorite being ATE Blau, but the Castrol Syntec is easier to find and almost as good for less money. Change every two years or more often if in wet climate.
Radiator? Custom Griffin like Q45tech has.
http://www.griffinrad.com/ I am not a fan of non aluminum radiators but others have had success with brass after market ones. Be sure to check the lower metal pipe and thermostat cover as they act as sacrificial anodes.
The Stillen Brembo are now sold as the Stillen Sport Rotors by Brake Pros, a division of Stillen. Occasionally, Joe will run a special, but I know he is too busy now. Maybe in a few months.
http://www.brake-pros.com/product.asp?i ... &model=Q45
