I concur with all said here.Nothing like a black QX4AZhitman wrote:THAT is simply AWESOME!!!!
I'd go with the lowest lift that will help with tire clearance...
That's pretty sweet Jimmyzzer!So, have a favor to ask...can you or someone else help me out a bit, trying to lift my '03 Pathfinder.jimmyzzer wrote:i just put the 2 inch lift from ac on mine.if i was you and you didnt want to worry about going to high get the 1/2 inch springs from ac.i did end up putting the warn hubs on mine.
I know it's something I should've known -- thanks for going easy on mejimmyzzer wrote:if you put it in 4 wheel with the hubs unlocked it will just spin the front drive train not the tires so its still like 2wd.the full time hubs spin the front drive train all the time even with the transfer case in 2wd.but now in 2wd and the hubs unlocked nothing is turning in the front saves the cv joints plus like i said i do get just a little better mpg.
NICE. . I dig older Chevy trucks. That's actually why I wish I could do it . . for the sole purpose of screwing around in 2lo. . hahaI'd personally have no practical reasoning behind it.jimmyzzer wrote:yes i can run in 2 low when i had my chevy it did do great burn outs like that.[ig]http://links.pictures.aol.com/pic/6aa07 ... 3Ig=_l.jpg[/img]
jimmyzzer wrote:thats the kit i bought.2 inch springs.they do have springs that only have a 1/2 inch lift also, but not package.the manual hubs stop the cv axles from turning all the time cause of the angle.with the hubs unlocked i do get a little better fuel mpg.i dont get alot of the topping out from the struts unless you really hit a hard bump.the strut tower mounts bolt to the top of the strut and hold the spring to the strut,they turn with the strut.mine were still like new so i used mine but if yours are old you should replace them.the spacers go on top of the struts to give more lift but it puts the cv at more of an angle.i do still have the stock wheels on i wanted to let the springs settle down some.to put 31 on you have to change the rims cause the tires wont clear the strut.you do need the camber bolts for the alignment.it did take the tire shop here about an hour to do the alignment.i dont see any tire wear yet.
Jimmyzzer, sounds like you (or anyone else?) may know about this...how much of an offset would the new rims need to let the 31" tires avoid hitting the strut (on an 03 Pathy with a 2" AC lift)?jimmyzzer wrote:to put 31 on you have to change the rims cause the tires wont clear the strut.
We used to do this all the time in a Suzuki Samurai, we'd get a bit of weight in the back, and put it in 4-lo, unlock the front hubs, then pop the clutch.. We'd usually get a fair sized wheelie out of it. Wouldn't last long (and who knows how long the drivetrain would last doing that anyway), and we'd run out of steam fairly fast anyway.KoukiS14 wrote:I found this bit "Also, certain vehicles enable you to select a 2WD-Lo mode by unlocking the manual hubs and shifting the transfer case into 4WD low-range. "
