my question is simple, what can i look for, im no mechanic and short on fund. so im hoping some mechanic out there has seen this before and can help me. thanks
ITs leaking from the calipers, hoses are fine.Ace2cool wrote:I can't really tell from the picture what the problem is. If it's leaking from the calipers, try tightening the 4 bolts on the backside of the caliper (should be either 12 or 14mm.) Those bolts sandwich the caliper together.
I'm assuming it's not leaking from the hose, as you posted a picture of the front side of the caliper.
t.mcginley.jr wrote:The calipers are 2 pieces, Like Ace said, there's 4 bolts that hold both halves together. There are 2 o-rings in between the two sides for the fluid passages. It's more likely that your piston seals are leaking. The caliper rebuild kit from Z1 is are $30 I think (for the fronts)
Always, whats a house without compressor. how many time has one had to deposit 1 dollar to fill up tires. it adds up, used compressor. Priceless.Ace2cool wrote:Easy if you have access to an air compressor. Otherwise, not so much.
Yup no seals between the two halves. and they were nasty, i only did one and im pissed off. ill wait till tomorrow to do other side. it doesnt leak so im not to worried but its next. bled them and all is dandy. one side is clean other isn't. lolt.mcginley.jr wrote:Holy crap there weren't any seals in your brakes?! They must have been oozing brake fluid 24/7!
And expect to get dirty when doing anything with brakes due to brake dust (= black).
Yes, the clips go through the holes in the pins.KiDoZ wrote:Hey fokes, i just notice something.
in this picture borrowed from the right up. does the retainer spring feed through the pins on the one end. it just dawned on me the pin was inserted wrong also. Dam, got to take it apart again. only the pin and retainer clip.
but does clip feed into pins???
http://www.nicoclub.com/wp-content/uplo ... 2/12/2.jpg
but retainer wont go in pin, if it does go inside the pin, then its broken inside it. clip wont go into pins.Ace2cool wrote:Yes, the clips go through the holes in the pins.KiDoZ wrote:Hey fokes, i just notice something.
Also, you did put some O rings in where they were supposed to be, right? Otherwise it's just going to keep leaking.
