DELUNASC wrote:Whats the story with the BG - 44K treatment? Is this an additive I can add my self? Where do you purchase?
Thanks for your help
There are multiple sources. You can contact
http://www.everythinginfiniti.com (ask for Joe Tsensky) and get it from them.
Another source is eBay - pick somebody who has lots of positive feedback on sales of BG-44k. By the way, do not confuse this item with other products from the same company! You should be able to get it for about $12 to $14 a can (it is 11 ounce of liquid in a metal can) plus shipping.
Then, the procedure is simple:
1. Go to a gas station when you have less than half a tank of gas or so.
2. Using a long (or flexible spout) funnel, pour in one can (11 ounces) into the gas tank. Be careful about the funnel you use - some will not tilt enough to allow the liquid to go into the tank!
3. Immediately fill up the car with premium gas.
4. Go for a long drive (ideally). If you do not have the opportunity to take a long drive, that's okay ... this is not critical to do - just do your normal driving.
5. Let the tank get really low before you fill up again! Do not dilute the BG-44K treated gas with untreated gas too soon, in other words!
6. Repeat only once with the very next tankful if the treatment has not cleared up the issues with your car and engine ... you should not do more than one or two BG-44K treatments every 3000 miles. But, doing it every 3000 miles is a good idea!
If the BG-44K treatment does not work, then you may need to get an injector rail flush (remember to ask the dealer to do the powered rail flush, not just another treatment with the Nissan equivalent of BG-44K!)
Some people also like to do this BG-44K treatment a few hundred miles before an oil change (i.e., a couple of tankfuls of driving), but I have not found this to be particularly required per se. I do not know the value of this point ...
Note that the Chevron Techron additive product, even in the "concentrated" bottle sold in typical auto parts stores, is not as good as BG-44K. No comparison in quality whatsoever. Do not get fooled into buying that as an alternative!
However, note that Chevron gasoline, with Techron additive, (and probably also the new Shell gasoline - I do not know the additive they use) is an excellent gas to get for your car. In many cases, a regular diet of Chevron 91 will remove/reduce many performance ailments!
Z
