adrianfromthecastle »
https://forums.nicoclub.com/adrianfromthecastle-u30128.html
Sun Apr 19, 2009 11:08 am
okay, just recently, I've noticed on the freeway, when I shift to 5th, it will sometimes grind, same goes when I downshift to 4th from 5th. I just recently changed my transmission oil, to maybe see if that was the issue (because its been more than awhile)... but it still happens (well, less often than before the transmission oil change).
I just want to know what my possible options are. Is there some kind of additive I can put in my transmission that would help this? Or are my synchros already effed up to where I need to either rebuild or source out a new transmission?
