Postby
nicc_dett »
https://forums.nicoclub.com/nicc-dett-u86442.htmlMon Dec 22, 2008 11:45 am
im using a tire iron to remove my lug nut but every time i turn the tire iron, the lastlug nut just spins freely and wont come off.anyone have an idea how i could get this thing off?
Postby
SullivanRacing06 »
https://forums.nicoclub.com/sullivanracing06-u63212.htmlMon Dec 22, 2008 12:05 pm
sounds like youve got a stripped stud or lug, put the iron on the lug and pull the tire out and twist the lug wrench, that should help it come off, if i were you id grab a set of nismo studs n some spacers.
Postby
lovespeed »
https://forums.nicoclub.com/lovespeed-u54066.htmlMon Dec 22, 2008 1:57 pm
first off that sucks. but i have been there many times.... trie to but pressure on the back side of the nut as much as possible. you might trie prying on the tire with somthing to put more pressure on it also air tools would help. but if all else fails cut it off and get a new stud.
