help, locked out
B13@15yrszold
Car: 1991 Nissan Senta xe
ii locked my keys in my 91 senta =[
Shift_Alabama
Car: 1996 Mustang GT
Just call a locksmith, it's really cheap. Last time I locked my keys in my 240 they only charged me $20.
Nikku
Car: 1999 Sentra GXE, 69k miles
here is what u do. ( tends to work with older cars )
1.) get urself a coathanger.2.) Bend it strait3.) bend 1/4 of it up like so | | | \ | \ |
4.) Now slide it inbetween the window and door.5.) turn about 50 - 90 degrees6.) pull around untill u fill it catch a bar7.) pull up on bar8.) remove coat hanger and open door
you gotta think 'GHETTO' in these desperate situations. if you were real desperate or *cough*wanted a cd player*cough* you could use ur antenna! LOL
Maverick7687
Car: Sagemist(FSO) 1998 Maxima SE & Charcoal Metallic(KG2) 1993 240sx & My newly aquired Pearl White 1990
Insert in what part of the door?
Nikku
inbetween the window and door, like going down under the window, going inside the door
Modified by Nikku at 11:38 PM 10/28/2006
Maverick7687
I knew that.. Just trying to help out a little.. isn't there a specific place you have to go along that line or does that bar go all the way across?
The Siath
Car: 99 Nissan Maxima, Arctic Pearl White, VQ30de, 5MT.
Nikku wrote:inbetween the window and door, like going down under the window, going inside the door
Better to call a locksmith - easy to break the plastic connectors - (I know this is late for the original poster - but thought it good information for any readers of the thread.) - if you break the connectors you will not be able to get in from the outside of that door till you replace them - which can be a pain on some models ( my G20 would be a nightmare of wires and bolts) just to get into the panel... best advice - before you lock your keys in your car - get an extra set made put in wallet/purse -
