steppinsx »
https://forums.nicoclub.com/steppinsx-u14944.html
Wed May 05, 2004 7:19 am
I'm hoping someone can help me with the "noise".I've searched through the threads a few times and still can't figure it out. I have a nasty knock that comes and goes. I can almost produce it at will. It happens when I maintain rpms greater than 3500 or so for longer than say 30 - 45 seconds. I think it is a lifter/rocker arm noise since it will go away if I let it idle at 1k for 10 -15 minutes. It will stay gone as long as I shift at or below 3500 and don't maintain the peak for long. Comes right back if I keep the revs up. There is no power loss at high rpms (actual gains since the port and other mods).It's not the injectors. It's not the timing chain. Both are new. The timing chain guides went and caused a hole in the cooling channel, overheated, warped the head. The head was tanked, milled to flatten it, broken guides replaced, ported, oil channels blown out and the gasket replaced. The timing chain, guides and front cover were all replaced.
My thoughts: 1) Bits of the guides in the oil plugged up the oil channels? Ran Gunk and Seafoam in the oil. Oil pressure is good I think (20@idle, 40@2k, 60@3k).2) Faulty head rebuild? The rocker shaft torque was not correct or even. I retorqured it. The head work was done by a shop that didn't have much experience with Nissans.3) One or more lifters are bad? I couldn't feel any play in the rockers but they were all slightly discolored as though they had been overheated.
I'm thinking now I should replace the rocker arms/lifters. Are these one unit or separate? My Chilton shows them as one but other pics iv'e seen show them as two (the fsm is on the way).
Any help would be appreciated.
89 240sx, n/a KA-e, Injen intake, Hotshot headers, 150k miles
