slipnfall »
https://forums.nicoclub.com/slipnfall-u4227.html
Tue Apr 19, 2005 12:10 pm
Hi there, This should have been such a simple task... 120k on my '92 S13 M/T, and so I decided to change my open diff fluid(99% likely it's original) just for peace of mind. Well I drained out about 1qt+ with the front end on ramps. Drain plug had minimal sludge, so there didn't seem to be excessive wear.
Anyways, I bought two quarts of Valvoline SynBlend 80W90 to refill. I called a local transmission shop and my dad to ask about refilling. I wasn't sure because the diff isn't level when the car is(it tilts towards the rear). Both my dad and the shop told me that the car should be level, *not* the diff. I fill it up, letting it stop dripping out the drain plug, so it should be level with the hole. This is the way the FSM illustrates. I also noted I could not refill with nearly as much fluid as I drained out.
I take it for a test drive filling it this way, and about 2miles down the road get the most gawd awfull screeching from my rear end. I knew immediately that it must be low. Drove another 1/2mile gingerly and called for some help(gotta love women... ).
Jack the rear way up, squirt some more fluid in, and plug it back up. The 2+ mile drive back home was better.
So WTF... Should I put a bubble level on the bottom of the diff, then refill(this was my original assumtion, but this is what I get for trusting the 'professionals'. The FSM wasn't very verbose about the leveling.
Also when I pulled the drain plug originally, I heard a 'hiss', like air entering or escaping. The transmission shop told me that the fluid will foam, so re-check the level later. Is this what the vents are for, to vent air outwards? How can I check that my vents are clear? He also said that over-filling will force fluid out the vents.
Thanks for reading folks...-Jamie
