HELP! leaking radiator fluid
deevietboi
Car: Nissan 240sx 1990
so my 1990 240sx fastback started to leak fluid like crazy today.... its not coming from the radiator but seems to be coming somewhere from under the manifold area. what do i need to do to fix it?
any ideas asap thnx
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
Check your radiator hoses first. You have a upper and a lower radiator hose. If it's spewing out then you probably have a crack or a tear in one. It may have just come loose and just needs tightening.
240marcuSX
Car: E34 525i
E46 M3
check your radiator hoses and heater hoses.
Those are the only things in that area that could be leaking.
Report back.
deevietboi
cant seem to see it or even get my hand in there but ill keep trying
thnx guys
any more things that could be it? its leaking on my transmission so somewhere around that area if that helps
deevietboi
ok so i did nothing and theres no leak... wtf?!?!?!? is this a bad thing?
adrianfromthecastle
Car: 1992 Nissan 240sx
deevietboi wrote:is this a bad thing?
yes, unless you don't mind your motor overheating. any cracks on your radiator? my oem ka radiator frekkin cracked one day when i was pushing it hard...
positron1
Are you sure that it was radiator fluid that you saw?
paulie240sxr
Car: 240sx 91 hatch
is it just pooring out or spraying everywhere if its spraying everywhere then it could be your water pump,bottle neck where your thermostat is located (i had it happen to me )
phuphyter
Car: 2002 Infinity G20
paulie240sxr wrote:is it just pooring out or spraying everywhere if its spraying everywhere then it could be your water pump,bottle neck where your thermostat is located (i had it happen to me )
I had that happen to me too.
It could just be your water pump. When's the last time you changed it? When it goes bad, coolant flows out the little hole on the pump. I heard you can temporarily plug it with a small screw until you get it fixed.
killablue240
Car: sr powered s13 coupe, 1991 twin turbo 300zx
there are three hoses that run under the intake manifold that are a real pain in the as to get to. fill your radiator with water and run the engine and watch it to try to figure out where its coming from.
paulie240sxr
Car: 240sx 91 hatch
yeah but if its the
killablue240 wrote:there are three hoses that run under the intake manifold that are a real pain in the as to get to. fill your radiator with water and run the engine and watch it to try to figure out where its coming from.
but if its the water pump it sprays everywhere and you really cant tell cause the pulleys , fan blow it around (i spent 3 hours trying to figure it out after useing stop leak stuff that cost 7.99 a quart )
deevietboi
positronone wrote:Are you sure that it was radiator fluid that you saw?
well radiator fluid is green right? thats whats coming out
no my radiator isnt cracked
um and the patch a radiator thing doesnt help cuz its not radiator thats ****d
member how i said the leak stopped... well today it did it again... but just a little came out this time (last time lots of **** came out)
last time it was spewing out crap and steam has coming out but this time it just leaked (no smoke)
o if this helps my radiator catch can is cracked....
paulie240sxr
Car: 240sx 91 hatch
that could be your problem if its to full it will do that don't fill it past minimum and see what happens
deevietboi
paulie240sxr wrote:that could be your problem if its to full it will do that don't fill it past minimum and see what happens
OK TODAY IT STARTED TO OVERHEAT... so i stopped it popped off the radiator cap and stem came out (is that ok) then turnd car on and poored water in it. heat went down..
no leak but the heat up was scary.. didnt want my baby to die
any thoughts about this?
tonynalli
your heater hoses need to be replaced. you said it your self that the leak is under the intake manifold. Honestly its not that difficult just cut away the old tubing and replace with new tubing.
