NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Sun Aug 21, 2005 5:00 am
You should do both the sensor and the harness. The harness is like 12 or 13 dollars, compared to the sensor that is chump change. The sensor comes in at about $174. The sensor is a voltage generating crystal. When struck it can generate up to 1 v. Since the voltage is so low its signal in the wire can be influnced by radio frequency or high voltage compnents such as the coils. Therefore a shield needs to be wrapped around its signal wire to keep out undesireable interference. That is your second wire going into the connector. It is a sheilded ground the stretches from the ECM to the sensor and ends right at the sensor connector.
