Peabody »
https://forums.nicoclub.com/peabody-u10351.html
Tue Feb 26, 2008 1:19 pm
I had a wobble in my pulley and when my friend's shop pulled the old pulley off the crankshaft where the key goes in is all messed up. The hole is much larger and the key does not stay in. He thought he could JB Weld the key in place put the area is to wide and the JB weld does not work. He said I should just swap the motor. I really do not have the money to pay someone to do a swap and wanted to know if there is anyway to fix the crank so that the key will fit.
I talked to another shop and they said they could try to grind the crank and weld the key in. Not sure if that will work. I am the original owner and the car has 170,000 miles and runs fine. I am not sure if I should just sell the car, fix the KA or do a swap with a SR20.
The only mods I did were a header, Air intake, computer/chip swap. The interior is almost new and the exterior does not have a ding,dent or any problems.
I guess I really want to know if a crank can be repaired or am I wasting time with my old crank?
THANKS
