I'm a little confused about this:
1. Locate the body harness (under dash harness that attached to the ECU) that attached to your old harness. Cut the old connector off (the one that attached to your SOHC harness) and attach your DOHC body harness connector. Just match the colors!Yellow/Red --TachYellow/Green--SpeedometorOrange--Ignition startBlack---GroundBlue/Black---Water temp sensor
I've found on a couple write ups but I'm confused which colors correspond to which harness. If anybody could make it moreclear that would be awesome.
ALso how would I go about using the sohc power steering lines on the dohc??
