HELP!!! KA24DET RANDOM NO START
Sweethappypants
Car: 1993 s13
Hello everyone, I'm new here and was wondering if anyone could help me out. I have a no spark issue on ka24det; however, it's not like any of the other ones on here though. One day I had spark, the next day I didn't and I haven't had it in about 2 months now. Battery voltage is fine. All my grounds have about 0.1 ohms. Required voltage is going to the coil, module, transistor, and distributor. Cap, rotor, plugs, wires, coil, distributor, and module are all new and look fine. The car will crank all day long, but I just can't get spark. I use to have spark and could fire it up, but not anymore and I haven't done anything to it. http://www.youtube.com/watch?v=B_DOF9sal_UI have checked everything that i could possible think of and all has turned up normal. If anyone could help me out, I would greatly appreciate it.Thank you for your time.-Michael-
r3v_v3ng3
Car: 91 fastback ka-t
do you have fuel?
S14Juggalo
Car: 95 240sx (S14)
Check your plugs and your plug wires make sure they are not disconnected inside the casing. If those are fine try to mess with the time a little to see if maybe your dizzy moved out of time. Thats all i got for now bro.
S14Juggalo
Car: 95 240sx (S14)
Also check your ignition fuse in the junction box in your engine bay that very well could be the culprit. And if it is its only like $3 or $4 for a new one.
Sweethappypants
Car: 1993 s13
I have fuel, and the timing is fine. I just have no spark. It would still spark if timing was off, just at the wrong time. Plugs, wires, and cap are fine. All the fuses and grounds are good. Thanks though
