i found this does it help?Align cams to sprocketsThis is the step that we missed the first time around--it's not nearly as hard as it sounds when you're actually trying to do it, and if I ever do cams on a KA24DE again, this is how I will do it, rather then messing around with marking the chain. First, make sure you are still at TDC. Then, make sure the chain isn't bound up anywhere on the idler pully. Put the exhaust cam sprocket in the chain, so that the slot forms a 90° angle with the surface of the head. (IMG:
http://www.az240sx.org/albums2/telekine ... rocket.gif)
Once you have the sprocket lined up, put a wrench on the cam, and rotate the cam until the dowel in the cam lines up with the slot in the sprocket. At this point the sprocket should slide easily onto the cam and you can finger-tighten the cam sprocket bolt. Then, position the intake cam sprocket to match one of these two pictures, based on whether the dot pressed into the exhaust cam falls on or between links:(IMG:
http://www.az240sx.org/albums2/telekine ... n.gif)Once you have the sprocket positioned, rotate the intake cam with a wrench until the dowel pin lines up with the slot in the sprocket. Slide the sprocket on, finger tighten, and check again to make sure you are still at TDC in cylinder #1.
