HELP!! KA24DE major problem. I MADE A VIDEO. WATCH IT.
ZOOMIGUEL
Car: 1989 240sx SR20DET
2006 Lexus IS250 AWD
WATCH IT
http://www.youtube.com/watch?v=P7RcAIbOUs0
ok so i just got in a car wreck, i got tbonedand when i did i had my car in 2nd gear, then bam, SHUT OFF. so it worked fine after i started it when i got hit, blah blah worked fine for about 1 week..... then i went on interstate and i got it to 105+ then i came back home and drove it again and it didnt work as well as it did an hour ago.... nowi have to floooor the gas pedal to get barely any speed.
watch the video
could it be transmission?
please help
Modified by ZOOMIGUEL at 9:41 PM 9/15/2007
albert_ey
Car: 2007 Nissan 350Z
Maybe your clutch is bad? Check fluids in transmission and diff.
ahryell26
Car: 1992 nissan 240sx hatchback
damm, that sounds bad to me. ur right it could be ur transmission.
funigui
Car: I HAD a 1991 240sx coupe. woked NA motor. ran like 14.5 ish. blew it up @ 140 after an ECU reflash.
no it sounds like ur fan clutch on ur fan is seized!! go outside and grab ur fan and try and spin it
ZOOMIGUEL
okwell i will check all fluids first thing tommorow,
and about the fan thing, my fan once or twice completely stopped while i was driving, and i had to get out of car and move the fan cover which had stopped it couple times, but now its fixed and i think that might have ruined the fan
you think ? how can i fix the fan?
Fahaka
Car: '96 S14 '07 Versa
is this an automatic transmission?
I think it is based on the vid. It is definitely in need of help. seems to be slipping profusely, maybe a bad torque converter or something.
Time for a 5spd swap
funigui
if the fan is sized, buy a new clutch or install aftermarket electric cooliong fans
ZOOMIGUEL
funigui wrote:if the fan is sized, buy a new clutch or install aftermarket electric cooliong fans
ITS A 5 SPEED TRANSMISSION
so the clutch is out basically?why do i need cooling fans when the fan spins? i meant that my fan got caught couple times and completely got stoppped and engine ran for 3 mins with out fan spinning.
engine does get hot tho.
ps. new radiator last month
RCG_Savage
Car: '92 240sx fastback
The fan clutch not the clutch.
Fahaka
holy crap that is a 5spd...yeah it is time for a new clutch. I thought it was a auto with a 3k stall converter...lol
ZOOMIGUEL
Fahaka wrote:holy crap that is a 5spd...yeah it is time for a new clutch. I thought it was a auto with a 3k stall converter...lol
alright
so how much you think it will cost me to get a new clutch replaced?
1000-2000?
because my car was 1200$
or should i buy another 240
do you guys suggest instead to spend that money on a new 240sx 1991 with 120,XXX miles 5 spd for 1200$?
whatd do you guys think.and if so how much should i selll the bad clutch 240. i will post pics
Modified by ZOOMIGUEL at 10:58 AM 9/18/2007
Lost_In_Translation
Car: 1991 Nissan 240sx, stock with many problems.
A new clutch??? maybe 300 installed more or less I'm not sure...
B-Boy DuB-L
Car: 1993 Nissan 240SX
Y WHERE U GOIN 105+ THATS NOT VERY SAFE OR SMARTI AT LEAST HOPE YOU HAD A RADAR DETECTOR GETTING CAUGHT BY THE COPS SUCK
Fahaka
do the clutch yourself...
dnlx5
Car: 91 240sx s13 hatch 5speed sr20de (crashed but still driving)
i think depending on the severety of the t boning somthing in the driveling might be binding or rubbing causing the clutch to have to work harder proove me wrong or but another 240 i dont like the idea of driving a car with damage n e ways
FattyInA240
Car: 90' 240sx fastback sr20det
through out bearing and slave cylinder bad sounds to me?
FattyInA240
[QUOTE=FattyInA240]through out bearing and slave cylinder bad sounds to me? [/QUOTE............ sounds like u need an sr20det w/5spd swap the whole damn thing u'll be much happier
albert_ey
Yeah your clutch might me around $120 and installed around $300. I'm pretty sure it's your clutch that's worn
P.S. I'm talking about the clutch for transmission, not fan clutch...
ZOOMIGUEL
I CAN SWITCH CLUTCH MY SELF?
I HAVE NO EXPERIENCE IN CLUTCH.BUT ENGINE WWISE YES.
OK WEL HERES THE DEAL.
i got 1178$ from insurance , and to fix the body of my 240 is about 500$ if i do it myself... but then theres the clutch... i dont know if i should pay to get it done because i have no clue about clutch and i dont know how much a clutch would cost in a auto mechanics.
so if the clutch is less than 700$ then i will do what you guys say,,,,and i found a 240sx 1993 120K miles. for 1200$...... so either fix my car or buy a new one ..
and ... how do i check the clutch to take a look.
is it easy?
ZOOMIGUEL
what my car looks like at the moment,
SORRY, JUST TOOK PICS IN DARK
Lost_In_Translation
You can do a clutch swap yourself just search for a writeup on how to do it. And of course having a friends is a must to easily drop the transmission. Shouldn't cost much more than 150 if you do it yourself.
ZOOMIGUEL
ok, i foung the write up
... so is it hard at all? can i f**k up? i will hopefully get all the tools and materials by this sunday.... then i will try it out sunday or monday..
any TIPS on what to be careful for guys?
ZOOMIGUEL
BUMP!
ZOOMIGUEL
COULD IT BE I HAVE NO TRANSMISSION FLUID??
HOW DO I CHECK EXACTLY TO MAKE SURE ITS MY CLUTCH..
BECAUSE I DONT WANT TO HAVE TO CHANGE THE CLUTCH WHEN IT WAS THE SMALLEST THING
ZOOMIGUEL
BUMP!
should i check the transmission fluid?
i bought some lucas trans fluid , but i dont know how to put it in my transmission?
ZOOMIGUEL
B-Boy DuB-L wrote:Y WHERE U GOIN 105+ THATS NOT VERY SAFE OR SMARTI AT LEAST HOPE YOU HAD A RADAR DETECTOR GETTING CAUGHT BY THE COPS SUCK
well
ive gotten 131 MPH on my speed radar.. AND ON MY GAUGE CLUSTER THE SPEEDOMETER WAS DOWN WAY PAST 110 ... HAHA
and yes i have A VALENTINE radar detector, its very sufficient and lets me know when theres a cop from 2 mile radius.(saved me about 15 tickets)
albert_ey
Yeah there is a write up on checking the transmission fluid on here.
Here is the link:http://www.240sxtech.com/
Look for the Transmission and Drivetrain section. You will find everything you need to know there.
Florida240sx
Clutch swap cost you $15 in gear fluid and probably 4hrs for labor. I can do in 2 Shops usually charge 250-250 for labor. I got a guy that does it for 100 Make sure you resurface your flywheel.
ZOOMIGUEL
well im gonna look , see if ican do it myself, then i will see if a shop can do it for 200$....
B-Boy DuB-L
ZOOMIGUEL wrote:well
ive always wanted to ge tthe valentine radar but i dont want to spend 400 on it are you trying to sell it by any chance
