HELP!! ka24de getting only 20mpg
S13_PoWar
Car: 93 240sx Coupe SE
for sum reason my car gets only 20-21 mpg regardless of a/c. i changed everything and even cleaned my maf. wat culd be the problem. is it the fuel filter??
VietGQ
Car: 89 s13 240sx
have u checked ur lines maybe theres a leak somewhere, and when you drive do you smell fuel?
matt_240sx
Car: 1993 240sx Hatch
thats the average mpg for a ka24de.
did you even look it up before you posted this?
blacksrjdm
Car: 89 240sx, 99 CBR900RR.
When you say you changed "everything" what does that mean????
If you havent already changed them here is a list to start.
Cap RotorWiresPlugsFuel filterGet a fuel additive to clean the injectorsOil changeTrans fluid changeDiff fluid change
If you have done all this, evaluate your driving...
Are you the kind of person that keeps their foot to the floor and shifts at redline? Or are you the type of person that drives conservatively, shifts at a low rpm, doesnt give excess throttle etc... Obviously if you are driving fast everywhere and shifting fast and flooring the car all the time, then you are going to get terrible gas mileage...
But actually, you are getting the proper mileage for the car, so, keep up the good gas mileage. Put a turbo on it, then you will see your mileage drop...
http://fueleconomydb.com/specs/NISSAN/240SX
Check that out...
S13_PoWar
i have changed everything on ur list blacksrjdm the only thing i nvr touched was the fuel filter
blacksrjdm
Well, change the fuel filter and you will be done tuning up. Although you are getting better than avg fuel economy according to the chart there so... Seems to be you are doing pretty good.
baron_harkkonen
Car: 1993 Nissan 240SX, 2005 Honda Civic
look for a vaccuum leaks after the MAF sensor, and throttle body. Fuel filter wouldn't affect mpg, it would affect the overall performance of the engine. i could be wrong, and if i am i'll admit to it. change it and see what happens.
S13_PoWar
thx ill change it 2m or wenever n ill keep u posted
nightsauce
Car: 1991 Nissan 240SX S13 hatch RIP
1992 Nissan 240S S13 hatch :D
20mpg....sounds average to me :]
xX RB Xx
Car: SE3P, FC3S, FC3C.
Have you tried changing the way you drive?
that might improve your MPG's
str33tprintz
Car: 1996 Nissan 240sx SE
S13_PoWar wrote:for sum reason my car gets only 20-21 mpg regardless of a/c. i changed everything and even cleaned my maf. wat culd be the problem. is it the fuel filter??
well um... I dont even get that... though I drive like I stole it sometimes. My altima (automatic) which is heavier with the same engine gets way better gas mileage. And I've just come to expect that, didn't really buy this car for gas mileage though.
Metal Angel
Car: 1990 240sx hatchback
I am so scared of what my mpg will be if I go ka-t.
darens13
Car: '93 240sx, '90 chevy 1500, '49 dodge pickup
how does anyone get that bad of mileage? i run the snot out of my ka and it returns 27 mpg. i have gotten as high as 29 in mixed city highway driving.
xX RB Xx
darens13 wrote:how does anyone get that bad of mileage? i run the snot out of my ka and it returns 27 mpg. i have gotten as high as 29 in mixed city highway driving.
because most people drive like they are on the drag strip.
S13_PoWar
i dont think its da way i drive. i shift at 3 grand tops nothing higher and the engines perfect even tho it has 160,000 miles. NO leak or burning oil at all. Also guys, can a sr20det fuel filter fit on a ka24de??
-RJ-
Car: S13 Convertible, 99 Frontier, 03 Sportage, 96 Protege
run seafoam through your intake system, check you tire psi and see if your air filter is clean
also if your about time for an oil change, put seafoam into the engine and run it for about 10 minutes then change the oil
btw i get 24/29 on my car, very light on the throttle and shfit at 2.5
kc240guy
Car: gold s13 and a maxima
I get 24 mixed and 32 on long highway trips. I don't drive just in town, but i do know that when I went to a drifting event 70 miles away and drifted while I was there and came back I still got 28. So I would be worried if I got 20.
xX RB Xx
S13_PoWar wrote:i dont think its da way i drive. i shift at 3 grand tops nothing higher and the engines perfect even tho it has 160,000 miles. NO leak or burning oil at all. Also guys, can a sr20det fuel filter fit on a ka24de??
It all depends on how hard you are on the gas and brake. Even if you shift at 3k but your hard on the gas, you going be using just as much gas if you went to 6k but were smooth on the gas.
S13_PoWar
UPDATE: i changed the fuel filter yesterday $10 at advanced. it was a pain in da butt to change but i havent noticed anything yet. ill keep u guys updated. also something seems to rattle fromda engine when i hit 4 grand and only 4 grand i can't seem to find da place where its coming
samxini
Car: '95 240sx w/Kouki conversion
Is it that "marble in a tin can" sound?Might be your timing chain guides.Or the heat shield on your exhaust manifold.
xX RB Xx
samxini wrote:Or the heat shield on your exhaust manifold.
bingo.. its something to do the exhaust
Rauland-S13
Car: 1989 Nissan 240SX Coupe
I was getting 19mpg in the city, 32/33 mpg on the highway with conservative driving. I've since changed my O2 sensor, knock sensor, and put on a cold air intake and my first tank of gas got me 24mpg. And thats with me driving VERY agressively in town (spinning my tires, redlining it, hard shifts, heacy accel, hard braking).
Maybe its time for new sensors.
initial_jc
Car: KOUKI
I have a 97 KA'DE and i get about 23-24. maybe a little more
S13_PoWar
tea samxini your rite it does sound like a marble in a tin can but ill check the timing chain guides and heat shield thxill keep yall posted
safin
Jerid
Car: 1993 240sx Hatchback
I average 17-19mpg, driving like I'm on a dragstrip. I've been meaning to see how it does when I baby it, but I can't keep my foot off the floorboard.
BTW, it's a 93 hatch ka24de. New plugs/wire/fuel filter, air filter, etc...
ThuG LyFe
Car: 95 S14
i drove mine like a grandma and still only got 20-22mpg average with maybe 40-50% highway. i live in nyc so i know there's a lot of stop and go and city driving but the ka just sucks at fuel economy.
with that said, i don't believe anyone that says they get like 28 mpg city and 36 on highway. my corolla gets that, not a 240. i hate how my car got same mpg as my dad's TL but 2x slower.
chaosli
Car: 89 nissan 240sx coupe FTW
99 mazda miata
93 bmw 325i RIP
my ka-et gota little less than 9mpg before i killed the motor it was not tuned so ya...
